Ohio, I think you would be pleased with the Cyclops LED replacement lamps, one year ago I installed a set in my 2013 GT. The company I used to work for laid me off because I wouldn't retire, I would get to work between 0400 and 0430, check the property, check with the night shift, make sure the climate control started and have the shops ready by 0600 for the day shift.
My cut off was 35 degrees, below that I drove the truck, summer in Georgia was just miserable if traffic stopped but that summer morning ride in was glorious. All that to say the Cyclops LED are canbus compatible, were a MAJOR upgrade over the original incandescent lamps, mimic the original light pattern (many LED replacement lamps DON'T as they won't work with the factory headlight reflector) are a pain to install if you have large hands. After the VTX1800 with the "Daymaker" LED replacement headlight with the 2 additional "driving" lights also converted to LED I wanted bright white light down the road on this scoot; I went through the forum and web offerings to see what was out there and decided to try the Cyclops, that was all I needed. I actually got up early this morning to go for a "dark" ride, the headlight STILL impress me.
