Okay, coming home yesterday (about a 100-mile goofing-off run, with a lunch stop in the middle), the bike seemed to be a tiny bit louder under acceleration, and running maybe 10F° hotter than usual on the coolant temp display. And at times -- I got stuck in a traffic jam near home, because a road was closed because of an accident -- the temp creeped all the way up to 220° or so.
And when I first noticed this (before the traffic jam), I decided to go in full WFO mode a couple of times, maybe 15 minutes apart. The top end was now, both times, at 73mph, on level ground; that's down from about 89 (and just the day before, I had the scoot up in the 80s a few times).
When I got home, I waited an hour or so, and fired up the bike in the garage. I wanted to see if there was a fan problem. Nope. Eventually, the coolant temp reached 212°, the fan kicked in, and the temp dropped to 202° a few seconds later. I let this cycle repeat itself four or five times, with the exact same numbers. So apparently no problem there.
I checked the oil level, per the manual's instructions (up to temp, shut off for a minute, level bike, don't screw it back in, etc.) The oil level was exactly at the max mark.
I checked the coolant level, and it was low (green is max line, yellow the min line, and red is the top of the actual coolant):
So I called Max BMW in Troy (NY), and got an appointment about four weeks from now! Mostly, I wanted to see if they could pull any fault codes, check out the scoot, etc.
Today, I drove over there (i.e., in a car), bought some coolant, mixed up a pint (with distilled water), and this afternoon got around to adding it to the overflow tank (pictured above). I got a special flexible funnel, with a nice built-in container and an on/off control under its bucket. I managed to stick the hose in the top of the overflow tank, and watched as the funnel's bucket emptied, and tried to also watch the overflow tank (which is a real PITA to see).
When the funnel had completely emptied, I took a good long look at the overflow tank. Here's this afternoon's pic of that:
I thought it looked remarkably similar to yesterday's pre-coolant-addition picture.
So I looked around, and discovered a puddle (wiped up before I took the pic, but you can see the contrast in the floor color):
It appears that somewhere down the line -- past the overflow tank -- and somewhere down the road, I have developed a coolant system leak. Further, sticking my finger in some area way down there, it seems that the bodywork can capture and retain some coolant ... up to a point, anyway. I found a very wet area down there, a little to the left of center.
I discussed the lack of top speed, etc., with a couple of the techs at Max's today, when I was picking up the coolant. They asserted that since I got no blinking, flashing, text, etc., warning messages that they were confident that no harm was done to the bike. And that I should fill up the overflow tank, and go for a short test ride. (And one guy suggested I add some Techron to the gas). Well, that test ride is out now.
I plan on driving back to Max's tomorrow, see if I can talk with the GM, and try to get some loaner bike. I mean, I bought the bike there last year, ordered at the end of last May, and had my two service appointments there (the bike has c. 5,600 miles on it). This shouldn't happen to a bike this new.
If I don't have any luck with a loaner or moving up the service, maybe I'll try to contact Motorad USA. And maybe go a few hundred yards down the road, to Troy City Garage, and buy a new Honda Navi or something, to keep me on two wheels in the interim.
That's my report.
That's my report.
