650GT General warning light flashing RED
gaza4569
Queensland Australia
Hi I have a 2017 650GT that displays a red warning light. Its traveled1650KM. I have checked everything I can, oil, coolant, breaks, ect. I have recently replaced the battery (it was tested and faulted) thought it may have been that causing the problem. Bike rides fine any ideas?
Garry Queensland Australia
Usually the warning light accompanies another 'symbol' on the dash that tells you what the precise issue is. Look for another small symbol somewhere on the dash that looks unfamiliar - there really should be none visible best I recall.
Tire pressure over inflated or under inflated by many lbs of air. So the RED
light warning will FLASH. I have over inflated tires n i took out the air to
get it within 3 or 4 pounds over
