e7navy1999
Here is how to change your gearbox oil C600 Sport.
Thanks again Delray. How many miles can one expect out of a Chain on the C600 Sport? I see the 15k recommendation. Thanks for the part numbers. Also...do you happen to have a wiring schematic for at least the headlamp section please? I am putting on fog lamps and want to run them with the headlamp circuit. Hoping the canbus will not give me an error. if so I will just use a 12v relay of the battery. relayed powered by the key switchDrawing is for the BMW C 650 GT. It's for changing GEAR OIL and the correct spec is 250 ml.
500 ml is the correct spec for the CHAIN OIL, which is what the video shows -- that's not gearbox oil. Both call for 75W90 oil.
The chain case has chain rails that are replaced every 15,000 miles. They help maintain proper tension. Info below.
BMW 33 35 8 533 983 CHAIN RAIL AT 15K - STAGE 1 0.18* 1 * $26.29
BMW 33 35 8 533 984 CHAIN RAIL AT 30K - STAGE 2 0.20* 1 * $26.29
BMW 33 35 8 533 985 CHAIN RAIL AT 45K - STAGE 3 0.20* 1 * $26.29
BMW 33 35 8 543 854 CHAIN RAIL AT 60K - STAGE 4 0.24* 1 * $26.29
When a new chain is installed, you reinstall chain rail #1, so anyone replacing chain rails should hang on to them for future use.
