justscootin
BMW Maintenance Schedule
This is your 600 and 6000 mile inspection
As for the oil it is important that you use the 15w50 sj ma2 oil they recommend as the sj oil will not hurt your cataletic converter. This oil is only available from bmw (not cheap). I have found other brands but they are not cheap either so I decided for the extra couple of bucks I will stick with BMW so I do not void warranty.
BMW Motorrad *
Maintenance schedule
0133 - C 650 GT
00 00 119*BMW Running-in Check (see Maintenance Schedule)
Setting service-due date and countdown distance * *
Performing vehicle test with BMW Motorrad diagnostic system * *
Changing engine oil with filter * *
Checking front/rear brake-fluid level * *
Lubricating side stand * *
Checking basic setting and braking effect of parking brake * *
Checking play of throttle cable * *
Checking coolant level * *
Checking tyre pressures and tread depth * *
Checking steering-head bearing * *
Checking lights and signalling equipment * *
Function test, engine start suppression * *
Final inspection and check of roadworthiness * *
Confirming BMW Service in on-board documentation
BMW Motorrad *
0133 - C 650 GT
