RE: Headlight assembly waterproof?
HSG
Oahu, Hawaii, USA
I use a low-power Ryobi pressure washer, and know better not to point-blank the jet. With that said, I noticed water getting behind the headlight. Anyone else experience this?
You can pull a cloth edge tight and bring it under the light, saw it back end forth to bring that edge higher behind the light, hopefully that will fix your problem.
  • Like
Reactions: HSG
I appreciate it - I really want to know if this is going to be problematic driving in the rain. It rains here often, and no way out of driving in it.
No problem at all during riding in the rain, l have done a lot of that. If a few drops get behind there that method l described should be ok for that.
  • Like
Reactions: HSG
