Squeaky brakes.
Tux
Australia
Over the last few months my front brakes have been squealing, seems to get worse in the cold.
Finally got sick of people looking at my loud EV, and took it to the dealer,
Was told there is a replacement campaign on that issue at the moment and the disks will be replaced.
It's going to take one month to get the parts in. looking forward to the silence of the CE 04 again soon.
Has anyone else had this issue?
I've read on Facebook France that some people had the same problem, some of them had a badly mount calliper.
Yes, mine are squeaking more and more and today while moving at a slow speed and not touching the levers a sound and feel similar to disc grinding occurred. Wtf was that?
My front brakes have become intolerable at around 10,000 miles / 16,000 km. I've tried cleaning the rotors, but it still returns. Symptoms sound very much like what @SeaE04 has described. Anyone get it sorted out?
I was just about to check the forum again as mine continue to squeak and it drives me nuts and sounds so cheap. Reminds me of a kids bike caliper brakes.
Same here the more the temperature goes down the more they make noises, I will talk to my dealers about replacing them.
Thank you
Yves
Try removing the brake pads (if these are traditional style calipers and pads) and coating the outside contact surfaces (the ones that touch the pistons and the 'grooves' in the calipers that the pads side in - obviously NOT the friction side of the pads that press against the rotors) with grease. There is special grease for this purpose, maybe you can find it at typical auto parts stores. This is commonly done to prevent brake squeal like you describe and is supposed to be done on installation of new brake pads.
Although from all your reports, it sounds like a more serious design flaw, but it doesn't hurt to try it out. On my C650 (as well as my other two BMW motorcycles) removing the pads to do this type of service is a matter of minutes, the calipers do not need to come off their mountings.
Me again,
I when to my dealer last week, on the the senior tech toll me to buy some rim cleaner to remove the dust from brake on wheel apply on the brake and caliber, let it soak and then wash it with a pressure washer. The thing is we don't use our brakes that much so they get really dirty. He toll me even on the Porsches ev there brakes squeak as well.
Cheers!
Safe ride everyone!
Yves
Hello Everyone I've use the technique that the senior tech toll me to do and it work. I've remove the front fender (2 parts) it take 5 minutes to remove the fender with a torx screwdriver or ratchet who work better, then you apply some rim and wheel cleaner on the callipers generously wait 2 to 4 minutes then wash it with a high pressure washer (Karsher) them may as well clean the fork and the other parts since your fender is off. Et Voila no more annoying brakes until the next time.
Cheers !
Yves
I’d like to suggest that pressure washers aren’t really a great idea where motorcycles are concerned. Seals and bearings are relatively exposed on a bike compared to an automobile where with a PW you are mostly just cleaning off an outer shell. Personally I have always used the time-honoured bucket and sponge / microfibre mitt with some ‘auto’ shampoo. The dealership isn’t at all concerned about longevity where your beloved machine is concerned, so tend to have at it with quick-fix solutions. It is much easier to loaf around pointing the PW wand than actually bend over a little, or horror-of-horrors get down on one knee, and move your arm around washing the machine. While you are doing so you will also more easily observe any little issues that aren’t apparent from ten feet away.
The brakes on the CE 04 suffer from significant under-use compared to a regular bike. Honestly, the re-gen is so powerful that I generally only use them for about the last 20yds of stopping. Consequently the discs and pads get quite dirty and accumulate greasy material from the road. I would try the above tools and an old toothbrush and pay particular attention to the drilled holes in the discs — all manner of gunk can get lodged in there…
I haven’t tried removing the pads, but if the above fails then a common fix is to apply some copper grease very sparingly, i.e. just a light smear, to the backs of the pads only! If the pad and caliper are both ‘dry’ at point of contact, metal-to-metal frequency vibrations can set up causing that characteristically annoying squeal.
Here’s an example: https://www.holtsauto.com/products/cleaners-and-greasers/copper-paste/ There are many different brands out there…
Don’t what ever you do get it on the friction face of the pad, only the back!
*Edit — also don’t apply the stuff directly to the mounted calliper, like the guy in the second photo used in the above linked product. That’s a recipe for disaster!
Cheers !
Yves
Merci. I will keep this in mind for when my bike (potentially) develops this problem. Thank you very much for sharing what you were advised to do, and for you experience trying the process.
