Surge on takeoff
It could also be clutch worn, not engaging at lower rpms. How many miles has it run?
Non-stock clutch springs can do this too, Malossi red for example.
stock ones are white
Mine has started slipping and vibrating at start after 20000km, and was replaced by Dr.Pulley by 35000, huge difference.
If you read 2016 BMW PR release with focus, they spell “softer lining in the clutch”. I would not trust to buy another from BMW.
Just speculating, but it could also be your clutch bell is worn out by previous “harder lining”, definitely check everything incl. inner diameter. Malossi’s white springs (“T” of the three in the set) should work if you have all else is good but non-stock springs installed.
