Yesterday I went to change a drive change adjuster in the rear drive. I have attached 3 photos one of the pictures shows stage 1, 2 and 3. You may notice the largest hump that is stage 3 and the smallest is the stage 1(that I removed) I then installed stage 2 and have stage 3 on the shelf for next time (in about 25,000km. At the present time I have 29,000km on the odometer. This maintenance is called for when there is 15mm of play in the chain. While doing this work I also changed the rear drive oil with a half litre 75W90 synthetic gear oil that is what is called for. I found about .7 litter I drained out. (my garage still smells)
I saw a few posts in the past that the entire chain set has been replaced (your dealer took you for a ride) and only the adjuster had to be replaced at a cost of about $30 and Labour (I did myself). I also kept the stage one so someday when the chain set gets replaced I will already have stage 1 in my hands
