I'd keep an eye on that tire. Usually in warmer weather the tire pressure goes up. A general rule or thumb is 1psi of pressure change for every 10 degrees of temperature change, up when warmer and down when colder. You typically don't see a tire pressure drop when weather gets warmer. Of course there are several variables that can cause temperature change in a tire besides just outside air temperature such as road friction, braking, etc. Although I've found mine to be pretty accurate when compared to a known good pressure gauge, many have stated that the TPMS sensors are not accurate. Although a good safety feature and can alert you to a sudden loss of pressure, you should still check tire pressures on some regular basis to confirm true pressure and accurate TPMS (RDC Sensor) operation.
