... Not even a T55 torx to remove the bolts on the rear tire.
What do you guys have in your tool kit?
The rear wheel has T45 bolts. AFAIK, the only T55 is on the grips.
The tool kit was designed for a guy like me; little mechanical knowledge and even less ability. You can remove panels, change the battery, and add lights or whatnot I suppose, but that's probably about it. Frankly, I would not have wanted to pay for more.
What about tools to change a tire?
So in my toolkit under the seat is:
Winchester Multi-tool, Neico 1/2", 3/8", 1/4", 1/4 hex combination ratchet, 3/8" drive T15-T55 Torx sockets, 5" Vice Grips, 4" adjustable wrench, ractheting screwdriver with Torx bits in handle, T9-T40 Torx folding bits, 5" flex head 3/8" ratchet, 1.5" and 3" 3/8 extensions, Tire gages, Fuses, tire valve cores, Spare Torx bits, Tire repair tool, set of screwdriver and torx bits, hex socket extension, hex socket to 1/4" adapter, hex socket to 3/8" adapter
In the small bag on the rear rack is:
12V air compressor, tire slime, tire repair kit, bungee cords, and rainsuit.
