Scoots you sir
I see there's been some posts about Tucano Urbano scooter coats / aprons so I thought you guys might like to see the mitts / muffs from the same maker I've just fitted.
They're the R333 model, which is a universal type but is a pretty good fit for my C600 (and presumably C650 too).
I have heated grips, but when it's really cold or raining I've always found mitts to be a godsend.
Some things to note:
For a good secure fit you need remove the bolts holding the handlebar weights on - they're massive M12 size and a torx key will not do the job. A torx bit (size T55) and ratchet is definitely required.
Two large washers are needed too which weren't supplied, so I had to source them myself.
I had to cut down the rubber cup on the right hand side so it wouldn't rub on the throttle.
The rigid design is good in that it stops them flapping about at speed and means they won't move backwards and tip the brake levers on you, but they can foul your arms a little when making large steering inputs.
My first post here - hope I haven't done anything wrong!
