2013 c650gt left turn signal light in mirror is out!
It is the whole mirror assembly and the mirror is on a ball/swivel joint that is very tight and you may break the mirror trying to remove it.
Like I said earlier the turn signal modual is not available separately from the assembly. To remove the mirror assembly you need to remove the side fairing cover and have a very short ratcheting wrench with a torx bit. The Rt side is easier to access than the L.
