Brake line
justscootin
Richmond Hill, Ontario Canada
Okay boys and girls, have close look at the area under the back wheel well. Now follow the rear brake line foreword and concentrate on the area at the area just above the pivot point. You may notice at rest there is about 1.25 inches of space. Now look at the plastic just above you may notice it being dirty but at the same time you may notice that your brake line has been rubbing rubbing or at least touched. This could be a safety concern in the long haul. You may want to show your dealer next time you are in for service or at least at your earliest convenience. Will the brake line wear through? Yes in time. Yes this is a safety issue. What your dealer does or says I do not know. Good luck
I went to the dealer today and asked about the brake line rubbing and he had no concern as the brake line has a stainless steel braided line on it and the odds of wearing through are next to none. He had no answer to the abs line.
I also traveled to the particular vendor right now and asked about the braking system series do away with and he zero matter because the braking system series includes a stainless braided series about it and the likelihood of wearing by way of are close to it's unlikely that any. He'd zero step to the particular abs series.
