C600Sport: Givi saddlebag mounts + Akra silencer...
SR50Dreaming
Australia
Interested to know if anyone has paired the Akra silencer with Givi's saddlebag mounts?
I've just purchased the saddlebag mounts (TE5105) however am concerned there will be little to no clearance with the silencer, especially once the bags are added :(
Is your new muffler that much bigger then stock? If not , you should be OK. A good suggestion is to not put heat effected stuff in the bag over the muffler, such as liquids, medicines , or food. Probably the time when you should be cautious is in stop and go traffic. You will probably be OK, but, do a trial run with frequent stops to check out if there is a problem.
