rongrimes
I find it's really hit and miss (more miss than hit) to get my handlebar locking to work. Anyone else having this issue? Is there a trick to it or does it need to be fixed by the dealer?
Ron Grimes
Ron Grimes
I tried your combination, but it didn't work for me. Oddly enough, after playing around with it, my secret combination is:I found that if my handlebar is turned fully to the left (typical parking position), the lock will not engage. So, when I stop to park, I turn the handlebar fully to the left, but then pull it back to the right a few centimeters/couple of inches, and the lock engages every time in that position.
If you are unable to find a magic position like this, where it seems that the lockable position varies from time to time, the dealer may need to find and fix the cause of that. I hope you are able to find the right position to lock it, so that you do not have to take you bike in for a fix. Good luck!
I found the same as other reports here, I turn to the left, then turn back just a little to the right and it locks there.I found that if my handlebar is turned fully to the left (typical parking position), the lock will not engage. So, when I stop to park, I turn the handlebar fully to the left, but then pull it back to the right a few centimeters/couple of inches, and the lock engages every time in that position.
