Heated Jacket Connection?
RRocket
CA
I have a 2016 GT. I want to hook up my heated gear lead which runs directly to the battery. This worked well on other scoots as the battery was under the seat and I'd have the lead poke out from under the front of the seat which made for an easy plug into my jacket.
But the battery on my GT is in the RH side fairing.
What's everyone doing in this situation?
hello friend, I strongly suggest to you to go for the 12v plug accessory to put under the seat. part number is: 61347694306 (maybe 61347714741 also). once installed, you will be able to connect your heated jacket and let the cable go under the seat, regards,
Interesting....but the heated jacket doesn't use a cigarette lighter type connection.
BTW...where does this mount under the seat? Are there wires all ready to go or do you need to splice?
