moodleman
Thanks Delray, perfectly clear now! At my age, I seriously doubt if I will ever need rails 2, 3, or 4!
....and you still bought another one???Mine was 2014 and had 2nd gen tensioner mechanical. It started making noise and found out it was tensioner.
I had the shops call and fight to get mine replaced. They called for over 6 weeks and finally was shutdown by BWM Germany.
I paid $1200 for the hydraulic upgrade.
This was the 2nd one. The first scooter I had was 2015 and did what yours did to the motor. Complete loss and now selling for parts.
And what has BMW said about it???My chain just jumped 2 weeks ago. When I opened up to get to the motor, I found that the motor has the old mechanical cam chain tensioner. This should not be. The BMW catalog shows a hydraulic cam chain tensioner.
BMW still makes C series. New C400 GT and the electric scooter....and all this is why BMW no longer imports, makes or sells the C-Series Scooter anywhere on earth. They decided to just AXE the poor design permanently, rather than spend any more $ on trying to make it EURO-5 compliant. (Everyone else did though...)They even axed the C-Evolution electric scooter they had for a while.
I really had liked the 650 Sport style redesign, but the mechanical underpinnings were still fatally flawed.
If you still want a maxi twin, since the Tmax isn't sold here anymore, new plan! Sell your C-600/650's for whatever you can get and buy the still available Kymco AK550. Solid, reliable and NOT built in China to the lowest possible price point. (And again, the BMW's drivetrain was NOT a Kymco design, they just oversaw the Lonchin factory FOR BMW, as they know scooters and are Chinese (Taiwanese) themselves.)
It was worth a try at the beginning! A new Maxi from BMW? My brother and I were both onboard and excited, with him already riding his Big Burgman 650 and me on my Majesty 400. Then the problems and recalls hit. And kept coming for the entire product life. It could have and SHOULD have been a different story, but unfortunately it was what it was. The good news is that both KYMCO and SYM looked at it all and said "REALLY? Come on BMW, it's not Rocket Science " and developed their own Maxis which are really good.
And through it all, Yamaha and the Tmax just kept OWNING the market, and it even has cruise control. Maybe HONDA will change things with the Forza 750? Who can say.
Finally at 22,000 km I decided it was time to change tension on the drive chain of my c650gt. Inspection through the little removable flap on the chaincase revealed a bit of slack in the chain. About half an inch. So changing up a rail should put everything OK again."I presume you would expect to change chain rail #1 first - probably at 20,000; then chain rail #2 at 40,000 and so on. Or do you change them all at the same time?"
My apologies if I was unclear. I said, "we are supposed to change chain rails every 15,000 miles ...". That's plural, and one could infer that there is more than one chain rail. There is only one, replaced in the same position by the next one. At 15,000 miles/24,000 km you take out #1 and replace it with #2. At 30,000 miles/48,000 km #2 comes out and #3 goes in. Each chain rail is bulkier to hold tension as the chain expands during the course of its life. I will go back to my original post and edit to make this clear. At 12,000 km, you're halfway to swapping out your chain rail (singular).
There was no recall to go from the mechanical to hydrolic tensioner. It was an updated mechanical tensioner but it was still a failure, I went through 3 of them then I paid for the hydrolichave read these tensioner are defective and it seems to me that the 2015s on should have had the hydraulic tensioners installed like was used on the recall of earlier models. Its also obvious that the dealership doesn't want any part of this repair.
Thanks kiss4u. I have it sorted now - tension rail changed from stage 1 to stage 2 - chain is now exactly right. Did it all at a little over 21,000 km, and it is an easy job. At my age, I may never need to do it again! (almost 80).Good evening,
According to the diagram you are referring to, the lower guide rail is number 3 on the diagram. It regulates chain tension.
In your photo, I can clearly see that this guide rail (the one that adjusts chain tension) is a STUFE 1. You can therefore order STUFE 2 (reference : 33 35 8 533 984)
