Have you check the manuel ?View attachment 6307
What does this mean?
Local dealer says bring it in, we’ll plug it in, and if it’s got a problem we’ll take it to Park Lane (London) because we don’t work on them anymore since we sold it to you.
Your 12 volt battery has a problem maybe it's dead you may remove it yourself and buy a new one or have a garage do it if so you will need to get a tow truck.View attachment 6307
That what I call bad luck from hell. hope things settle for you.A few days back I experienced a disturbing issue when I plugged in my CE 04 to charge. I had left it unused for only four days. The bike briefly fired up its display; locked the charge cable in place; shut itself down and then wouldn't start up again. I measured the voltage of the 12V battery via the pig tail connected to it and was horrified to discover that it was at 7 volts! So I connected a 13.6 V power supply (an Optimate 7 in power supply mode) to the pigtail to start up the bike and removed the charging cable. However, the bike was immobilised - it had just enough power to spin the back wheel on the centrestand but could hardly move forward when off the stand. Also, regeneration, reverse drive and the steering lock were disabled. I swapped the 12V battery for a fully-charged spare but to no avail. I was concerned that I had fried the electrical system with the 13.6V power supply. The following day I bought a generic OBD scanner locally from Toolstation; plugged it in and found that there were 18 fault codes. Once the fault codes were erased everything worked as normal again, which was nice.
My bike seems to be very poor at maintaining its 12V battery. Perhaps its because I have been using the heated seat (Level 1 of 3) and the heated grips (Level 2 of 3) all the time over the last few months and the inverter can't quite keep up. I have now started carrying a spare 12V battery and the OBD scanner in the under seat compartment.
Episodes like this make me think about selling my CE 04 since my nearest BMW Motorrad dealer is over 40 congested miles away in Wolverhampton and they probably wouldn't be able to fix major issues anyway. Instead they would likely send the bike to Park Lane in London. Since my bike is long out of warranty I dread to think how much all that would cost. My local BMW dealer, Roy Pidcock, went into administration a few years after I bought my bike despite doing a roaring trade in BMWs.
Here's a link to the OBD scanner: https://www.toolstation.com/streetwize-car-diagnostic/p12772
Thanks for your kind words. 12V battery issues seem to be common in EVs and I've learnt about OBD2 scanners now. In any case, if my CE04 breaks and I can't fix it then I have a C400GT as backupThat what I call bad luck from hell. hope things settle for you.
Yves
Did you get it sorted Steve? I bought my bike from Park Lane, will need running in service in the next few weeks, hopefully my local dealer can service it, not super keen to ride right through London just yet.View attachment 6307
Yes, I did. I drove it to the dealer who diagnosed 12V battery and replaced it.Did you get it sorted Steve? I bought my bike from Park Lane, will need running in service in the next few weeks, hopefully my local dealer can service it, not super keen to ride right through London just yet.
Yeah, when mine dies (it's a 2023 model but was new when I bought it a month ago) I'll likely replace it with a LiFePO4 battery. Did that with my GS years ago and it's still going strong.Yes, I did. I drove it to the dealer who diagnosed 12V battery and replaced it.
