Removing panels on 2013 650C GT
I’m trying to do the same thing. Are there any photos online to remove some of the centre console or around the gas tank area? I want to take off some panels so I can install some sound dampening material to see if I can quiet some of the engine noise at higher rpm.
Basically, start with removing the fuel cover (carefully!) and then work your way down.
1. Fuel cover.
2. U-shaped piece (behind the fuel cover)
3. Side painted panels (there's a couple bolts under the seat for this one)
4. Footrest panels.
None of the fasteners are really hidden; it just takes a little time at first to make sure you've got everything. Also, be sure to check the spring clips before putting any panels back on. They have a tendency to fall off and there's nothing worse than getting 90% of the panels on only to realize you can't screw something down.
I bought this from amazon.
Noico 80 mil 18 sqft car Sound deadening mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening.
