Valve Cap Warning!!
Scoots you sir
Dublin, Ireland
Not sure if anyone has posted about this before: don’t ever put an oversized valve cap on the front wheel of a C600 / C650 because there's only a tiny clearance between the valve and the brake caliper.
I put a cap with a built-in valve core extraction tool on my front wheel (just in case I ever needed one while out and about). A few weeks later when I went to top up the air I found the prongs had been worn down completely and the valve knocked about so much that only the cap seal was keeping the air in.
Luckily it was going to BMW for a routine service the next day so they fixed it for me.
I’ve used another cap of the same type for the photo to show what I’m talking about. The prongs make it about 7mm longer than the average cap.
By the way I very definitely use it on my rear wheel only now!!
Since I just bought four of these things (I'm doing the tires on the K1200LT shortly, and it uses the exact same valve stem as the C650GT) I figured I'd share the BMW part number with you guys if you want to order them from either your local dealer or from online.
The part number is:
36 31 76 53 064
My dealer charged me $6.21 apiece and I'm pretty sure you can get them cheaper (but I like to support my local dealer when I can so he'll be there when I need him).
