I found two causes for the engine vibration transfer.
1. the mounting bolt was way too tight, not allowing the cantilever part of the mounting to move .
2. the main cause of the vibration transfer is the slotted washer that under operation it touches ,ever so slightly, the outside of the mounting. this is enough for the vibration
to be transferred into the body of the scooter.
The fix:
1. Remove the nut and slotted washer on the right end side.
2. fit a copper washer with a 16mm inside diameter into the the bolt (photo)
3. fit the slotted washer back but this time with the slotted faces in the horizontal position ( see photo )
4. tighten the bolt again with just a good snug. Do not over tighten it.
In my scooter this simple mod totally transformed the smoothness of the bike.
