Akoprovic Exhaust
Hi, Just got a 2024 C400GT, Doe anyone know if the Akrapovic exhaust S-B4SO2-HRT will fit. Seems like it’s really the same spec as the 2020 but the website only shows it for 2019 / 2020. Thanks
I finally decided to upgrade my stock muffler with an Akoprovic exhaust.
I patently waited for 2-1/2 months to take delivery. I could’ve ordered from the USA but at greater expense….import tariffs into Canada.
Installation took all of 10 minutes. The most difficult part was the installation of the carbon fibre deflector. I didn’t want to scratch or crack it while tightening the 3 torx screws. A lower range torque wrench is required (16 ft pounds) for the muffler mounting bolts.
Exhaust note is definitely different. A deeper sound & a bit louder….I like it. Unfortunately I’ve been super busy and haven’t had an opportunity to ride the bike to see if there’s a difference in performance.
I have not decided to remove the DB killer yet. Removing it will void the warranty. The DB killer is pressed in and held securely with little bumps which mate up.
I did reach out to a YouTuber who has removed the DB killer to ask how he removed it……asked me to contact Akoprovic directly. It wasn’t the answer I was expecting. Removing the DB killer does make the exhaust substantially louder and throatier.
Hoping to take my C400GT for a ride this coming Sunday. Stay tune for my performance comments.
I just ordered a slip in exhaust on AliExpress. I will post the video on here once it's fitted for comparison.
I just ordered a slip in exhaust on AliExpress. I will post the video on here once it's fitted for comparisons.
Here is the £151 ChinaPovic exhaust off AliExpress. The sounds is near identical too an original akrapovic exhaust. Build quality is solid. Also the carbon fibre heat guard is also made from real carbon. Overall I'm extremely satisfied with this purchase and the great value. now I can annoy my neighbours with my amplified exhaust.
I've attached the link to the item. I just found this on AliExpress: £116.24 | C400GT C400x 2018-2020 Slip-on Motorcycle Exhaust Muffler Escape with DB Killer Laser for BMW C400GT C400X 2018 2019 2020 https://a.aliexpress.com/_EGsAEh6
I'm curious? Have you compaired this exhust to a real Akrapovic side by side. I believe that sometimes the parts you purchase form Ali are the real thing.
Damn that's a good bargain, too bad thanks to our Orange prez so many large aliexp parts are no longer being shipped by China traders, afraid of tariffs and complaints.
It’s definitely not the same as the Akoprovic exhaust by looking at xyxmeta’s last photo.
Akoprovic is oval shaped and no rectangular shaped with rounded corners.
I’d be interested in the performance comparisons between the 2 exhausts
...and it looks pretty Bad Ass!
bimmerc400gt-webp.5745
Do you know if this exhaust is compatible (I mean the mechanical parts—screws, mounts, and bolts—regardless of emissions regulations) with my BMW C400X, a 2024 model?
