Banging crashing noise, front suspension...?
Mitleider
Chicago, IL USA
Dear friemds, since new, when ever going over even lightly rough pavement, I hear a loudwhat sounds like plastic-on-plastic crashing sound/rattle. Clearly not right.
The bike has never been damaged in any way, nor has it ever hit a pothole or an obstacle that might have damaged the suspension.
I think,I've read where other CE-04 owners have experienced a similar quality issue. Does anyone have the same experience, and know,of both the cause and the fix?
Assume this would be covered under warranty?
Thank you!
Thank you!
Hello may I suggest that you put some foam insert ( Isolation foam 1/4 inch with on side that stick) on the edge of the trim panel at the front, I did so and it did a good job as well you may want to check all the panels to see if there is no loose screws.
Hope it help.
Yves
